Super six bbd
Slantsix64
Los Angeles
Bought this super six set up came with a carter bbd with the original tag still on it stamped 8193 S 0735 is this a super six carb the pvc connection does have a bend its not a straight shot
Are you sure it's not 8163? That works out to a 1977 Super Six. I couldn't find a listing for 8193.
Show us a couple pics, particularly a view of the choke lever with the camera parallel to the choke shaft, and a straight-down-from-above view of the air horn.
That's a BBD 8198s. Original application 1979 passenger car with 225 Slant-6 engine, not sure which emissions package. Yours is missing its choke lever, which is specific to the Slant-6 carbs and will have to be found used. It's also missing its choke pull-off to choke lever link (available new, Walker № R90).
Thanks guys! iam running a holley 2280 2 barrel currently and will try this one out after i throw a new kit on it
