volaredon
As title says.
I need the bracket for the cables at the manifold at least, the kickdown rods and such would be nice to have also but I have an aftermarket cable I can use for that if need be
also the stud from a BBD that the throttle cable and kickdown slides over/connects to. I'm running a /6 and a 727, if that matters.
Failing that, pix of the bracket that hold the cable housings in place at the engine with some dimensions would be a great help so I can fab something up
I just got my fresh 74 slant bolted into my 85 D150 that was originally a 1 bbl setup, already have the manifold stack and a NOS 318 BBD carb in place, just need to get it all connected.
