The heads are all the same the cam is a little more on the 2bbl motor so you need the manifold,carb linkages,and a mild cam to make it work good.With this garbage they call gas today I don't think I'd raise the comp to much .What really helped my slants both 170 and 225 was to increase the diameter of the exhaust from that punie 1 5/8 id to 2 in id and use a free flowing muffler. This one mod made more of a difference than anything else espically at highway speeds. The 170 really benifited from it the most.
