i just removed a pair of super stock springs from a 67 fastback barracuda.
instead of the numbers being 002/003
both are 003
whats up?
eddie
both are 003
whats up?
eddie
Some use the same part # on both sides so the car sits level, but I believe it's normally the right side they use and those are left side.
The numbers are clear
003
Will they work ok or
Will having 2 lefts
Be a problem
The S/S springs are an effective way to help control axle wrap up and provide you with the ability your looking for in drag racing.
S/S springs have been used in some pretty quick cars. A buddy of mine ran high 9's in a big block all steel (except hood) Dart with those springs.
While currently, there are more effective methods (for the rear end) to run that quick, a lot depends on the cars actual weight, balance, set up and power. As to when the limit of the springs occur.
I`d try them w/ a pinion snubber, unless your putting out a huge amount of h.p. w/ a bunch of hook, they`ll work fine !Years ago I tried SS springs for my spring wrap problem on my 67 GTS with a manual trans thinking it may help. In my case I had no difference from the original springs. Stock snubber was not doing it's job even after addressing that still had what felt like clutch chatter but was spring wrap. Ended up going back to stock springs to get rid of the truck like ride and clamping the springs with actually helped along with an adjustable snubber. Caltracs would have done the job but you loose the stock look and ground clearance.
You know it took me years to figure out what was going on. I'm pretty sure I had an adjustable snubber when I had the SS springs on. it still wrapped. It wraps then the car moves and the springs snap back so you would get what in the car felt like clutch chatter but it would shake the whole car. It could get so bad the wheels would hop. Now a snubber at 1" from floor keeps it from getting really bad and adding a clamp on the front of the stock springs helped too. The only time it was an issue is when you were letting the clutch out and increasing the power. Won't do it if you took off easy or slipped the clutch a lot with higher rpms. I looked into Caltracts which would definitely take care of it but I didn't like the low ground clearance with them. I still have the SS springs. I even got the front spring brackets that had extra holes to helped compensate for the extra lift of the SS springs. I suppose I could try them again. I thought they wouldn't wrap like the stock springs and was surprised they when they did. Not a lot of HP but always had good traction and 383 has good low end torque combined with a manual trans instead of an automatic that keeps a more constant torque out to the rear end.I`d try them w/ a pinion snubber, unless your putting out a huge amount of h.p. w/ a bunch of hook, they`ll work fine !
I use Competition Engineering adjustable shocks. I not saying there the best, but they are a good price and work for my set up.Which Drag shock works good if the original poster doesnt mind me asking?
Stupid question, did you have drag shocks on the car then.
History.... Mr. 4 speed even said that "They" would just simply "Walk the cars out most times."
Just how much power are we talking about from the engine.
Will they function ok
Drag racing?
For the rear, you need to measure the shock size you need with the car jacked up, with the axle hanging done. Then measure the size with the car on the ground. I will look and see if I still have the shock numbers.This one? (I think its the only one)
https://www.summitracing.com/parts/cee-2735/overview/year/1972/make/dodge/model/dart
