Sure grip housing... send it?
Take a run out and backlash reading on the current open diff set up.
Swap the ring gear to SG diff, install it, set back lash and if you want, run out. Drive it.
All SG's swap from case to case. Doesn't matter where the SG diff started, they all fit in other cases without issue.
Found some more questionable issues. Pinion gear has some wear on the leading edges, this one in photo being the worst. Ring gear looks beautiful, everything turns and feels really smooth. This is more than only cosmetic like the sg housing... but still...?
