DartGTDan
'71 Dart GT Fan
I've heard using 2 different tire sizes will damage the sure-grip unit in my 741 case 8 3/4" rear end. But, I've never heard how much tolerance, in tire diameter, there is before the damage occurs.
Per an online tire comparison calculator, my rear tires are 245/60R15 (26.6" diameter) and my spare tire is 195/75R14 (25.5" diameter). Is this 1.1" difference, in diameter, enough of a difference that it would cause damage to the sure-grip? If so, is there a "safe distance", and/or a "safe speed", the car could be driven until the flat tire could be repaired/replaced?
As always, thanks in advance!
