Suregrip additive?
68383GTS
East Peoria,IL
What do you guys use for suregrip additive? Also how much to you add to your gear lube? It has been about 12 years or so since I have swapped out a 3rd member. Going from a 410 locker to a 355 suregrip...
I use one container of the Ford friction modifier. It's about the best on the market.
You can also buy Royal Purple gear lube ! It is already in the oil ! But it is approx 25 bucks a quart !!! I do agree the Ford Racing friction modifier is really good stuff !! When I was working that’s all I kept in stock was the Ford Racing . Ford came out with a TSB years ago saying if you have a chattering problem in the rear end to use the Ford Racing Friction Modifier !!
With a cone type, I use the Valvoline pre mix. If clutch type Dana I would add the additive+ the Valvoline limited slip juice.
Mopar additive-
Is what I use. 4oz bottle from dealer is like $8.00. If you still get chattering after driving around and the rear gets up to temp- I add another bottle. Cone type rears like the one in my 741 case seem to need 2 bottles. I just use a good brand 80w90 gear oil. Napa or Castrol. If I don’t recognize the name I won’t use it. Never tried the oil that has it in the bottle already.
Pennzoil 4096, Gearplus 80W-90, now sold as Pennzoil Gear and Axle. Used and sold it since 1985. Limited slip additive already included in the formula. Never had a customer complaint about chattering, although probably more than half would have been used in open diffs. Wholesale price was pretty cheap, but retail markups can be very high. Yeah, $6.25/qt by the case of 12 on Amazon. $15.52 for a single quart.
Lucas also has a gear lube safe for sure-grips, I get mine at the local NAPA.
I found a full NOS bottle at a local antique mall, but I can not bring myself to use it.......
