Im just curious if anyone has used the forward strut kit from Mancini? or the weld on lower a arm plaes that stiffen them up? If you have what do you think?
i had the steel struts from mancini's that are a larger diameter than stock. i also had the lower control arm plates, along with all polygraphite bushings and 1 1/8" front sway bar on my scamp. that car handled great! i dont think you can waste money upgrading any part of the stock suspension. hope this helps.
