I'm starting to make plans for the next step of the build (hopefully this summer) for my 1968 Dodge Dart. I just want to wait till I start my internship before I actually start ordering parts and such just so I know I've got some money coming in. I'd like to make the Dart a car I can drive comfortable on long trips that would also be taken to some track days either on a road course or autocross (typical pro-touring kind of car). I'm a "spirited" driver.
The Dart has a 273 with low compression in one cylinder and is leaking a bit, ta 904 that seems to be working fine (just spills a couple drops of trans fluid every month or so), and a 7 1/4 with an open 2.94:1 gear ratio. I've also got an A-body 8 3/4 sitting in my garage with an open 2.76:1 gear ratio needing to be looked over and have U-bolts and shock plates installed.
I definitely need a suspension rebuild but don't know what parts to go with. I'm thinking about parting a suspension rebuild kit comprised mostly of MOOG parts on rockauto. Someone on moparts already gave me a list for parts numbers. I'd like something suited for better handling as mentioned above. I was also thinking about getting T-bars from Firm Feel. Based off of what I'm kind of looking for, I did some calcs and that said I should go with 1.06" T-bars (I like a little stiffer feel anyways). If I'm going to be swapping out the diffs, I'd like to swap out the springs as well. My only problem is I don't know much about who sells good leaf springs. I'd like something to lower the car a bit and offer good handling. So far, for leaf springs, I know of Hotchkis, but I'm curious as to what other options there are (as I'd like to go to a TVS in a couple years anyways). I've heard of people going to a shop that will add more leafs to their setup already, but I don't necessarily want to raise the rear. Does de-arching the spring help keep it lowered or would I have to do something with the shackles? How much does this usually cost?
I was looking at probably purchasing this tool set from Mancini as I'd like to try doing the suspension on my own. I just don't know what else I'd need.
http://chucker54.stores.yahoo.net/unfrsuprotok.html
I've also watched a couple videos on youtube about taking apart the front end on an A-body; however, they had the engine out of the car. I'm not sure if I'll be able to replace the 273 this summer. I'd like to go with a mild/stock 360 for simplicities sake. I don't know if I'm getting too ahead of myself, but that's what I'd like to do.
I won't be able to get to brakes, wheels, and tires for another year or so, I'd think. I'm currently running KH disc brakes up front and 10" drums in the rear with a 1 1/32 bore MC (manual brakes). I've got an old power steering box (I think it came out of a 73-75' Dart) with a Federal pump (I think). And I'm running 205/75/14 tires on the stock steelies (I know this is a huge limiting factor in handling).
Any suggestions, tips, tricks? Should I get anything else if it will fit in my budget? Should I try fabbing up some subframe connectors? My only problem, again, would be having no access to a welder.
Thank you for all your help!
