trbodrt Well-Known Member Joined May 18, 2009 Messages 370 Reaction score 7 Location so. cal Apr 1, 2010 #1 Anyone have torque specs for front suspension on a 72 dart?
toolmanmike Moderator Staff member FABO Gold Member Joined Jan 18, 2006 Messages 84,092 Reaction score 94,722 Location Office Apr 1, 2010 #2 Tight! I'm sure there are specs. You may need to get online or get a manual from the library.
trbodrt Well-Known Member Joined May 18, 2009 Messages 370 Reaction score 7 Location so. cal Apr 2, 2010 #3 tight is right but i'd feel better with factory specs, just for peace of mind.
64SignetConv Well-Known Member Joined Mar 22, 2010 Messages 47 Reaction score 1 Location Fort Saskatchewan, AB Apr 2, 2010 #4 German torque - Gutentight .... but avoid Russian torque - Brokenoff!
mopardude318 Well-Known Member Joined Jan 7, 2005 Messages 10,916 Reaction score 2,607 Location Gilroy, Ca Apr 2, 2010 #5 Okay, right out of the Haynes Automotive Manual: Dodge Dart and Plymouth Valiant 1967 thru 1976: Front suspension torque wrench settings: ft lbs upper ball joint nut................55 lower ball joint nut................100 lower control arm pivot nut.....145 control arm upper cam bolt.....65 rebound stop nuts.................25 crossmember bolts................150 idler arm mounting nuts...........45 shock absorber lower mounting....50 shock absorber upper mounting....25 steering knuckle bolts (lower)....100 steering knuckle bolts (upper).....55 drag strut nut (front)...............40 drag strut nut (rear)................110 anti sway bar nuts...................30 tie-rod end ball joint nuts..........40 tie-rod end clamp pinch bolts......15 steering box mounting bolts......100 pitman arm nut.......................175
trbodrt Well-Known Member Joined May 18, 2009 Messages 370 Reaction score 7 Location so. cal Apr 2, 2010 #6 Thanks mopardude for the specs and not just some crazy comments, i appreciate it.
mopardude318 Well-Known Member Joined Jan 7, 2005 Messages 10,916 Reaction score 2,607 Location Gilroy, Ca Apr 2, 2010 #7 no problem at all buddy...let me know if you need anything else..
U Upon9pwr Member Joined Sep 21, 2020 Messages 13 Reaction score 5 Location Virginia Sep 26, 2020 #8 How about the torque specs for 7 1/4 rear diff. Bearing cap, rear diff cover, and retaining bolts for axel, wheel lugs would appreciate it.
