sbmopar318
1970 A body factory small block K member. Looking for mounts for gen iii 6.2 swap. Anyone have any experience??
TTI or Holley offer swap mounts for factory K member. The Holley moves the engine ahead one or two inches. Would work good for that Hellcat blower. They both offer the headers to fit as well. I like TTI better than Holley on that. TTI offers full length two inch primary that will still fit your factory K and torsion bars. Will need to relocate oil filter no matter who or what you use for mounts. I've done A body gen 3 swaps. Feel free to ask any questions.
Did USCT buy Schumacher? Thought I read or heard that.....
Not in the budget unfortunately or I certainly wouldGet a custom k-member with coil overs and a rack&pinion . You'll have the extra room and the handling. For a good suspension with no install issues I would contact. HDK HemiDenny on this site. By far the best fitting with no issues from every one that bought from him.
I bought an AJE in a project car thinking I was getting a good deal. It was a disaster getting the components to make it work. Most of the parts we had to modify. spindles didn't fit the uppers plus other issues. We have a fab shop so we were able to do the corrections . If you don't have the equipment to correct things beware and do your homework
My friend just bought a popular suspension. I won't say from who but nothing fit smooth and any QQuestions or help from AA person they didn't have one one answer. He just came here to have the mounts modified to fit after the second set. Some of the mount holes were 3/8 when they should have been 7/16. They told him just use the smaller bolts they'll fit the block . Make sure there are tight They said.
I was liking the TTI mounts aswell. Have the earls coolant crossover to help clearance. And plan to run the factory manifolds.TTI or Holley offer swap mounts for factory K member. The Holley moves the engine ahead one or two inches. Would work good for that Hellcat blower. They both offer the headers to fit as well. I like TTI better than Holley on that. TTI offers full length two inch primary that will still fit your factory K and torsion bars. Will need to relocate oil filter no matter who or what you use for mounts. I've done A body gen 3 swaps. Feel free to ask any questions.
Thank You. 2021 pullout under 5k miles. Have a new CRT 46RE manual VB trans going behind it.Sorry- but that engine is sexy as -“bleep!”
Sorry, negative on the factory manifolds. Set it in and try to put them on and it will become quite apparent. It's really too bad cuz factory manifolds are quite good.I was liking the TTI mounts aswell. Have the earls coolant crossover to help clearance. And plan to run the factory manifolds.
