Swapping 73 duster interior to 70-72 info wanted
Notanova73
Visalia ca
Hello I’m looking for information on swapping out my broken hard to find plastic interior in my 73 duster with the metal 70-72 kind. What’s needed besides the metal parts them selves?im even considering putting 70-72 doors on it to to get rid of all the plastic.I’ve looked on here and can’t find anything on it.thanks
Well, the metal sail panels are a start. They need to be modified slightly to fit around the 73+ quarter window latches, you basically have to cut a notch in the metal panel where the latch goes to account for the difference between the '70-72 latch and the 73+ latch. Then you need the earlier rear panels, as the 73+ rear panels won't fit with the metal sail panels. You will also need to figure out a way to deal with the gap, since the metal sail panels don't extend all the way back to the rear window like the 73+ plastic sail panels do. I used a piece of ABS plastic to make an extension of the sail panel to cover that gap when I converted my '74 over to the eariler '70-72 metal sail panels.
The doors are a whole different story. You either need to find an earlier set of doors, or do some surgery. One member here added the metal upper and lower panels to a later set of doors, it's shown in this thread
73 doors on my 70
73 doors on my 70
Thanks.yeah I’m sure it would be easier to get early doors that’s the plan.
