does anyone know if there is anyone making the early sway bar bushing brackets used before 73 that attatch to the k member? ive made a couple of sets and its a pain,just thought i'd ask.thanks, postcar.
Hellwig offers our K-member brackets and bushings as separate kits. The K-member brackets fit 67-72 A-body and 64-69 B-Body applications and are made from Laser cut and CNC formed 3/16" steel. Part numbers are:
thanks dave. i've built a couple of sets to replace torn up brackets and use the factory bushings. nice piece.i will keep you in mind the next time i need one. they're a royal PITA!!! to make.
