Sway bar type lower control arm difference
cudamark
San Diego
There was a discussion of sorts in one of the other sections about the differences in the '65-72 A-body lower control arms when they have the sway bar option. Somehow that thread has disappeared, so, I thought I would post what I had posted there so others will know about it. The '65 and '66 models have a unique sway bar bracket tab. It has an extra washer welded to the eye on the bracket as seen in this photo. In '67 and up, that extra washer wasn't there. The '65-6 type and the '67-72 type will interchange. It's mostly an appearance difference with a very slight bushing location difference. Insignificant IMO, but, I'll leave that decision to you. If you're doing a 100% factory restoration, that might be important to you. I've also seen a difference in some of the welded-in bumper plates on later models, but, it's very hard to see the difference with the control arm installed in the car. It's mostly the width of the plate and how it's welded in place.
Interesting facts. I'm sure it was for cost cutting but good to have the information. Sure looks like the cup would keep the bushing from moving around. Thanks for posting.
That was my for sale thread on the 67 to 72 arms. Mentioned they fit the early a bodies as the 65 66 ones don't seem to be around and someone may want to add a swat bar. This is a good place to discuss the differences and interchangeability of the lower arms and sway bars.
I have some 73 and style also. It would be nice to put a picture up of all three so the difference could be shown.
It looks like the early arms have the bottom link washer welded to the LCA, whereas the newer one have it loose.
