sbh126
I have a freshly broke in 440 that I'm trying to find some good quality oil for. In the past I have tried to use synthetic motor oil but I had read somewhere that it is not a good idea to put synthetic in a freshly rebuilt motor. Is this true?
Question 2, I have a custom ground cam and was told I should always use zinc additive or my cam would go flat. The zinc additive I bought says that it should not be used after the first 1000 miles. Is it ok to continue to use it beyond that?
Question 3, I did the initial break in using Royal purple break in oil 10w30. with 1 bottle of mobile 1 zinc additive. I plan on changing the oil and using the same brand oil and additive. Is it ok to use break in oil for the next 3000 miles till the next oil change? Do I need to change the oil at 500 or 1000 miles instead of the normal 3000 miles since its a fresh motor? What is a good, high in zinc, oil to use after the first oil change? Thanks for any help.
