Tag ID, need help
1970Duster
I have two cars and 3 fender tags what do they mean? I know they are option codes but what do they translate to any help would be wonder full.
Thanks in advance.
1970
FF4 G33 R11 V5X Y05 EN2
FF4 L2F8 EF8 B26 055133
E24 D31 (VIN number)
1974
Tag #1
N41 N76 R11 V6W V8W CTD
L31 M21 M25 M26 M52
CV3 F18 G11 C52 J25 J52
V16 U B41 C15 C16 C56
KG2 C6VW 000 C05 326296
E53/8 D34 (VIN number)
(Not sure if its a 3 or 8 haven't cleaned it to find out)
Tag #2
26 L2 098
(VIN number)
The first one is a '70 Duster slant 6 904 automatic Lh remote racing mirror AM radio black body side moulding and built on Nov 26 1969. I don't have the paint codes in front of me but I think FF4 is a green of some sort. I'm sure someone will chime in it to give an exact color.
The 2nd car looks like a mismatch between the VIN and the fender tag. Does the VIN on the tag match the VIN on the dash, core support, and door? The VIN you gave says it's a '74 slant 6 Duster but the fender tag shows all kinds of V8 options.
sorry the 74 vin match I just typed it wrong its VS29L0B
First tag... FF4= light green metallic, G33= LH outside mirror/remote, R11=2 watt musicmaster AM radio, V5X= protective body side mouldings/ vinyl insert/black, Y05= built for U.S. specifications, L2F8= L2=beige, F8= dark green (interior trim), EF8, carpet, headliner, insturment panel/ dark green, B26=unknown, 055133= production order number, E24=225 6 cylinder, D31=904
Second tag...N41= dual exhaust, N76= coolant recovery system, R11= 2 watt AM musicmaster radio, V6W= longitudinal sport stripe (W= white), V8W= roof and strobe stripe (W=white), CTD= unknown, L31= turn signal lite,/ hood/fender, M21= drip rail mouldings, M25= body sill mouldings, M26= wheel lip mouldings, M52=manual sunroof, CV3= unknown, G11= tinted glass/ all windows, C52= bench seat, J52= insturment panel mounted hood release, V16= unknown, B41=front disc brakes/ power/ drum rear, C15= special sound insulation, C16=console, C56=bucket seats??, KG2= frosty green metallic, C6VW= C= custom/ 6=buckets/ V=vinyl/ W= white, 000= full door panel C05= unknown, E53= unknown, D34= standard duty trans
Tag #2...26= 26" radiator, L2= unknown, 098= unknown
Vin for the 1974 car reads...V= valiant/ scamp, S= special, 29= 2 door sport hardtop, L= 360 1 bbl, 0= unknown, B= hamtramck build
There were a couple codes I couldn't find that are listed above as unknown. Maybe check and make sure that you have them listed correct. Hope this helps, Geof
I'll go look again, I know the car came from the factory as a 360 Duster with white Buckets, Center console and Fold down rear seat.
which trany this car had is unkown to me.
Did you mean VS29L4B? The 4 is 1974.
L2 is the designator for Build on Assembly line 2.
Sometimes it is better to post photos, it keeps the typos & guesswork to a minimum. ;-)
The B26 on the first tag and C05 on the 2nd tag are the build dates. Nov 26th and Dec 5th respectively. The ctd means the info is continued on the 2nd tag. The E53 is a misread or a typo....it should be E58 which is the 360HP engine. Yup, a photo would sure help...
It would have a 727....
I can't find my camera right now, I sad now, I'll have to find it
Okay it has been a while but here is my tags in question.
