WAYNE0
Is it possible to take the bolts out the hold the clutch to flywheel & slide the the clutch back alittle ?
Ok thanks ill give it a try. I just take the z bar out & adjustment rod to see if it gives me more room. Ive had it out so many time this past week i can do it blind folded lolFrom the bottom inspection cover, yeah I believe you can. You will probably have to back off the clutch adjustment so the throwout bearing can slide back and allow the pressure plate to come back.
Yeah, that'll probably do it. lolOk thanks ill give it a try. I just take the z bar out & adjustment rod to see if it gives me more room. Ive had it out so many time this past week i can do it blind folded lol
