So I am in the middle of a dash wiring project. I bought a roll of the non-adhesive black tape to wrap long runs of multiple wires. How best to secure the ends once you are done? What did the factory do?
If it's the same type of linerless tape I use, just stretch it to its' max and then wrap it tight while stretching. When this is done correctly you won't be able to remove it without a razor blade. If yours will not stretch then I can't help???
