I used a propane torch. It is easy to control, you know when it is soft enough. I used a paint scraper when it was hot enough from there with some care. Gum-Out carb cleaner easily took the remaining residue off. I followed that with a zinc (yellow) Rustoleum primer and smoke gray enamel top coat (rattle can). I did the whole underside of the car on my back with car on jack stands. Girl friend had just kicked me to the curb and so I took on the job. Between the beer and solvents, I probably lost a few brain cells on that job for sure. : )
Needle scaler. Did the first 3 with a torch and scraper. Never again.
You are kidding, right? You can never get there with that. Right???
Hard to hold the phone and run the scaler at the same time! I had this Valiant totally stripped of undercoating in a few hours.
Wow Jim. I stand corrected then. If I ever do another one, I'll have to try your method. Does it remove the paint also or just the undercoating? Thanks.
Goo Gone working well, but areas where the undercoat is thicker (corners, and nooks and crannies) are more difficult. Second coat of GG left on till next evening worked even better! May try scaler on the frame, especially those thicker spots, but I'm discovering rust spots in the floors, so probably won't use the scaler on those.
I'll be doing the primer/spray bomb on my back, as well...if I took it down enough for anything else, I'd never get to drive it!
What does it do to the good metal, does it leave and marks etc?. Does it remove the paint also or just the undercoating?
I have been doing these cars for years that tar like coating you refer to is factory undercoating/sound deadner propane torch and a scraper warm it a little and scrape it offStarted pulling the old fuel line, and, as I worked my way forward, realized the whole underside is coated in a dry tar-like material. This 1963 dealer rustproofing, a 70s JC Whitney thing, or what?
Any way to get it at least mostly off without blowing the car apart? I fear it'd turn into another unfinished project if I did that.
Thanks,
Steve
