I am removing my window crank on a 73 swinger,i removed the center allen bolt and the crank will not come off,is there a special tool i need to remove? can anyone help?
The handle might be stuck on the splines. I have had to take a small block of wood and place it against the door panel opposite of the handle and by using the handle and a long screw driver, gently rocking the handle back and forth to release it's grip on the splines.
had to take door skin off to hook up remote mirror hold back clip and bolt in top trim piece,put window crank back on with no problems,so far,so good,thanks again guys!
