- Joined
- Apr 16, 2009
- Messages
- 5,351
- Reaction score
- 7,855
I do not know much more?
Is it for sale?I do not know much more?
What's the difference between the 2 barrel and 4 barrel valve covers?Well, somebody's been into it- as @4spdragtop said, it's got 2 bbl. valve covers and a 4 bbl. manifold, so there's no outward sign of what truly lies inside. If it's really a 4 bbl. engine, then it's a '67 at the latest, a '65 at the earliest. If the 4 spd. has an output flange, it's a '65, if it's a slip yoke it's a '66-67. That's only if it was all born together. The motor mounts and brackets are early A, so '65 or '66, depending on the trans.
Oh, check the distributor- if it is dual points then it most likely is a 4 bbl. motor- single points most likely a 2 bbl. motor with a manifold swap. I *think* that looks like a dual point, but hard for me to tell.
If it is a slip yoke, be aware that the 273 and slant 4 speeds used a 26 spline output shaft (same as a 904) which is different from the '68 and up four speeds that used a 727-sized output shaft with 30 splines.I am betting on the flange and not the slip yoke.
I am kinda thinking he would have sent a good pic of that.
4 bbl. valve covers:What's the difference between the 2 barrel and 4 barrel valve covers?
Yup, you're right- the dist. body would be smooth on a dual point. That's a single point dist. Or maybe even an electronic dist. swap..?The Distrib looks like a Single-Point
Having 2 breather tubes on the valve covers suggests pre 67.
Good catch. Just can't quite make out the wiring tabs on the passenger cover. It looks like a 65 without the large tab in the middle.Having 2 breather tubes on the valve covers suggests pre 67.
More than that, check out Brewers site. Plus no one reproduces that linkage that I know of. Plus usually they are nice and tight.I would think the shifter and linkage would be worth a couple of hundred.
