Tell me about this 273 and tranny.
Here are a few pics.
What a shame.
This have been posted before.
But the only difference between standard and commando is the cam and pistons.
Everything else is the same
Come on man?
I got that, Look back over the thread, There was no way to tell what it was until the heads came off.
The heads came off and it is a pop up pistons super commando.
Come on man?
Does it make since now?
Read the thread
Dude take it down a notch.
I was not questioning you about wether it was a commando engine or not.
You posted that you did not know if you could save the bottom end. I was just pointing out...
  1. The info MAY have already been presented
  2. The bottom end of all 273s is the same so easy to replace
Perhaps I stated the obvious but dang why the hostility.
There is no Super Commando. Commando was Plymouth and Charger 273 was Dodge. Just to correct some information. I call them HP 273's if I don't know what they came out of.
There is not hostility here but your first post in the tread was it MAY be worth $200.
Really?
I am not sure what Mopar graveyard you live in but I sure would like to know how to find it.
Complete long block solid can 273 with a 4 speed bolted to it for $200 on the high side?
:wtf:
It might be able to be saved or maybe easier and cheaper to replace. You didn't mention if it a original engine you may want to restore or just an engine you want to build and use.
I have the balancer soaking to see if I can get it off.
If anybody local can use this, Come and get it.
72936 Arkansas
I will keep everything besides the shortblock and heads
And it runs.
Pretty sure it's not a 727 but a 904
Actually it was Feb 6th. But im just being petty.
Having 2 breather tubes on the valve covers suggests pre 67.
I'm really glad you got a 273 block that you can rebuild.
I have a 273 and like seeing them saved.
Good luck to you.
And it runs.
Good luck to you.
Thats a good buy.
It does not have the 4 speed and bellhousing and the flywheel, Then there is the 4 barrel intake to throw into the mix.
Are the motor mounts there?
Don't know.
All I know is the owner pulled it to drop in a 76 318. He said the 273 smoked he felt it was valve seals.
I wanted to pick it up but no room and I recently picked up a 79 318 with 90k on it.
Are there #'s on top of pistons? To see if its std bore. I soaked mine in marvel mystery oil.
Valve springs were also stronger 2bl vs 4bl. Not sure if if timing gears n chain were the same?
Those heads are close chambered and sought after. Don't be quick to get rid of anything.
72936 Arkansas
My calipers say 60 over.
3.685
