Robj
You use the same tester to test both temp gauges cold, middle and hot and and fuel gauges empty, half and full. They both react the same to the same ground resistance? It seems that other than the fact that the terminals on the back are mirrored, the mechanical innards should be the same? An unused good temp gauge could be used to replace a fuel gauge if you rewired and mirrored it to the terminals on the back? I searched the forums and didn't see anything but I'm sure it's been discussed and questioned before.
added- 70 Dart -standard dash.
