I thought I would post what I`ve found as a benefit to others that might have a similiar problem.I did not have functioning temperature or oil pressure gauges in my 68 Barracuda.A voltmeter showed a pulsating 2.7-4.7 volts to both the sending units.Never the same voltage on each pulse. You could ground each sending unit wire and get the gauges to go all the way up.Voltage was also present( the same) at each terminal on the gauges but they still wouldn`t react.Cluster was grounded well and printed circuit was all good. After removing the gauges from the cluster I used batteries ,1.5 volt each(2 then 3) in series and ran them between the gauge terminals. The temp gauge would go to full on w/3 batteries, whereas the oil would only raise the needle to half way.(4.5 volts should have sent the gauge to full.)While I had everything apart I opened the fuel gauge (the bi-metal switches were all covered in carbon on all gauges)and removed the voltage limiter and replaced it with a 5v chip,heat sink, and capacitor using the spot where the radio noise suppressor bolts down.I plugged the chip right in to the terminals on the back of the fuel gauge.After re-installing the cluster I now have all the gauges functioning(although I`ll need a new oil pressure gauge)and they are rock solid. A solid 5 volts is present at all sending units.These gauges were made to work with a certain amount of tolerance and see the pulses as an average( mine being around 3.7 volts, more than 20% ,enough to affect gauge function). So just because you have a gauge that`ll move to full when you ground the sending wire, it may still be bad. In addition,if you have power to your sending units and gauges make sure it`s a good 5 volts, otherwise you may experience gauge problems/failure as I did.I`d suggest the microchip install to anyone who has a gauge problem or would like to upgrade their cluster.I hope this can help those who are ,or have experienced problems with their gauges. - Longgone
