Temp sender question
dodgemahal
Illinois
Does anyone happen to know what the resistance value should be, approximately, for a temperature sender, measured across the stud on the sender to a good ground? Cold coolant. This is a 73 Dart, 225 /6.
The one in there now was 207 yesterday with ambient at 80 degrees. 234 today with ambient at 68. It doesn't move the needle with engine running. Once I saw the needle move up to normal range then immediately dropped back to zero.
