Luc
Member
I removed the cluster, and there are no wires attached to the bolts protruding of the temperature gauge. On the front of the engine, I have a sensor with a coil around it for the whole lengh of the sensor, but that one is going a sensor that was added under the console (see picture) That added sensor does work. The cluster AMP meter does work (the added one doesn't).
Since I don't see wiring going to the stock temp gauge, I'm wondering if the added cluster was an option from the factory ? What do you think and/or suggest ? I hate to see something that simply doesn't work. I want to keep the factory look as much as possible.
