TrailBeast
AKA Mopars4us on Youtube
I got a 26 inch 2 row radiator from O Reily's for about 200 bucks and the core is just a hair larger than the opening, and all I had to do was drill new mounting holes.
Out on the hiway it runs just about 185 with a 190 thermostat, and about 195-200 if it's close to or over 100 degrees out.
About 200-210 around town if it's around 100 degrees out.
I'm using an electric 18 inch S blade fan right now and it works just fine, but when I go to the 360 I will be shrouding a viscous fan with the 26 inch radiator.
One of the things I really like about the electric is that it is set up totally automatic, so it goes on and off at the temp that I have the thermostat set for.
With a mechanical fan the engine and pressure in the cooling system goes quite a bit higher when you shut the engine off.
This setup usually only comes on when I am stopped in traffic, but when I shut the car off it comes on by itself and gets the temp down lowering the cooling system pressure pretty fast.
I can pull in at a gas station at 200-210 degrees, and by the time I get done putting gas in it the temp is down around 170-180.
