dave225
Active Member
I have done some reading and it appears I can adjust my reverse band. The car is a 74 Dart Swinger with a slant 6.
The transmission in the morning (cold) has reverse but it is weak and noisy. Shifting back and forth from reverse to drive a couple of times get reverse working just fine. After driving it the trans works fine all day and then starts over with the problem again in the morning.
Will adjusting the reverse band remedy the problem? Fluid level is good and it shifts fine once warm.
Thanks for the help!
