Raupleminze
Hey guys,
I was able to help my brother put the 360 and 727 into his 71 Demon.
![](http://i184.photobucket.com/albums/x34/raupleminze/4B3F13CC-068D-4FAE-AE3B-6D923A2F0A8D_zpsoh4ihygj.jpg)
Everything went smoothly (no scratches, dents, or broken parts). However, I do have a few questions.
First off, he is running a set of HTC coated Heddman headers and it appears that one of the tubes is hitting the steering box. Has anybody else had this issue? I am guessing that we will have to pull the header and "clearance" the tube. Has anybody removed that driver side header without lifting the engine back out?
Secondly, during the install there was no way for us to drop it in with the passenger side headers on so we removed them. Any tips on the easiest way to install those? Should we do from the top or from the bottom? Also should these headers be used with a oil filter adapter of some sort? It looks like the filter will hit the headers or at least be a pain to remove since it is coming off the block at a 45 degree angle into them. The block is a 1995 Magnum 360 if that makes a difference.
![](http://i184.photobucket.com/albums/x34/raupleminze/52F266ED-812A-4E2D-9441-4486039BD6CC_zpsbgdelwyj.jpg)
![](http://i184.photobucket.com/albums/x34/raupleminze/96B52F78-6EB9-430D-B8F6-ED74F420E681_zps4siujn76.jpg)
Third and last (for now), it appears that the engine is not centered when you look at it from the center of the car. It is currently in a 340 K member from a 1970 Duster and I believe everything was done correctly. In the pic it looks like the middle of the K member does not line up with the middle of the engine (using the ballancer as a reference point). What should I be checking?
![](http://i184.photobucket.com/albums/x34/raupleminze/0D07A056-E587-4D7A-9BAC-254057BE147E_zpsknqlvtyx.jpg)
I am hoping to get these few things ironed out to continue progress on the build.
Thanks in advance guys!
-Brian
-Brian
