MPH and weight will tell you rear wheel HP.
(sorry for the OT ) but I would caution anyone into thinking automatically that strip mph/weight calculations are RW HP.
Th evidence says otherwise - even if half the caculators on the net claim it to be RW.
First, read the first few paragraphs of the link - but the important bit is quoted below-
http://www.stealth316.com/2-calc-hp-et-mph.htm
And lookie what he writes -
"MPH" is the terminal speed (trap speed),
"ET" is the elapsed time,
"224" is the empirically determined coefficient that includes the necessary unit conversion factors,
Here it is - "hp" is the peak engine horsepower output at the clutch (net power), and
"weight" is the the total weight of the vehicle (with driver) in pounds.
Now -
I don't want this to get into a p1ssing contest, and I know for some Im telling them the moon is blue - but...........
(and I hope 360Z28 won't mind me using his figures.)
The calculator provided in the link I posted says 525 CRANK HP.
So thats pretty close to 360Z28s appx. crank HP of 540 using his 10% losses and his own formula.
So..............whats the issue?
Lets look at 360Z28s #s -
IF - we believed the common opinion that the calculatoirs tell us RWHP - then he is making 525
RWHP,
OR -
590 Minimum at the crank !!! - and only running 127 mph.
So itd be obvious to anyone who's been at the track, that the 525-ish is crank HP.
(which he agrees with anyway)
So to the point - after a fair bit of research -
The only solution I can come up with is that they all basically still read CRANK HP.
.............some may read "low" - but whats the option? 590- 610 crank???
I think even 360Z28 would acknowledge thats not happening.
So the message is - don't assume the formulas are RWHP - assume Crank and add or take 10-17% and you'll know when its compared to what others have done.
Now back to your regular program
