Just my 2cents worth.LOL I went to the junk yard and bought a pair of springs out of a dart. took them home. took the springs out of my duster and made a 6 leaf per side spring pack from the best of the 2 sets. You may(will) need to get a longer center bolt. use a grade "8" from the hardware store. Round the edges of the bolt head untill it just fits the hole in the spring perch. Just use some common sense and look at how the spring packs are assembled befor you take them apart. Try to duplicate the original design. By the way u don't have to get a spring pack out of the same model of car just a mopar so the front segments are shorter than the rear. If you get them out of a diffrent model you will have to reuse your main(the ones with the eyelets)leafs. In essence you can build your own "SS" springs for under 50$. When you don't have much money you need to get a little creative. Mine has been togather for over 6 years now and none of the springs are under 30 years old. I'm running 255/60/15 tires on 7" wheels but there is room for 275's easy.
