*UPDATE* as promised
this car is my daily driver so i wasnt looking for a super clean install, only function and reliability. i am mopar to the bone, but i had to see for myself what all the hype is over this conversion.
i received my kit from Greg. i went out and hooked it up and i must say i am extremely impressed with the results. I elected to keep my stock mopar EI components in place just "in case" i ever want to go back or if i sell the car. for anyone that is interested, this is what i did:
i chopped off and used an old EI distributor connector to attach to Gregs distributor wires off of the GM module to plug into my distributor.
instead of hard wiring the ballast connector wiring, i used plate connectors to directly mate my ballast connectors together.
i left my coil in the stock location with the ground wire still attached and mounted the new coil next to my wiper motor on one of the studs. i used male and female connectors to run power from my existing hot coil wire to feed the new coil 12v.
i had to drill a hole in the heat sink and mount it with the ground from the Module sandwiched between it and the fender, using an existing hole.
i re-gapped my plugs to .048, the rest is a plug in.
the results are fantastic. this car starts and runs like it never has. the spark is so intense, i can hear it working inside the cap standing outside the car with the hood closed. i barely power brake this thing with 235/70/15s and 2.76 gears and it just instantly lights em' up where it had to work before to do it.
if i ever need or want to go back to my factory stuff all i have to do is plug my ballast back up, hook the power wire back onto my old coil, plug in my distributor and my coil wire. the only tool i would need is a wrench to tighten up my positive coil wire. im sure for as long as own this car , i wont need to, but its there just in case. i did not cut one original wire for this install. i wrapped every thing up in electrical tape after these pics.
it could still benefit from a better rotor and possibly a timing change, but i have not done either, yet.
