Might want to warn the neighbors to cover there kids ears.....
The manifold is coming off a nice running 84 truck 360 that eventually go in my 74 Duster project.Why are you taking the manifold off? If its a valve job or rebuild cut the head off and let the machine shop worry about it
The owner of the truck the motor came out of had the honors mangling most of the manifold bolts.If you rounded the bolt that badly trying to break it loose, let if soak in penetrating lube for a couple of days- give it a good soak and gently smack it with a hammer (just to set up vibrations so penetrant can soak into threads) every day for a couple days, then go the drive a socket on it route and back it out. If you twist it off, you'll learn a whole lot of new expletives (trust me on this one...lol)
Cut the head off, pull the manifold; now you can get to the meat.
The motor is from an 84 pickup and its on a stand, I've been soaking and beating on it........I think tomorrow's the day.....X3!
If you don't want to risk maring the manifold, use a 5/16" Drill bit to behead it that way. You need a right angle drill. But then again, that's like a must have tool for Mopar, with their soft as cheese fasteners.
