Pazactly!
Exactly why I'm not allowing unlimited comp ratios. Sell a 14-1 360 to the average customer and see what happens! J.RobAnd also, if I do this build, i figure i will sell the engine after the contest, that should cover the build costs i think.
As long as the piston carries a SHELF STOCKING NUMBER. It isn't a custom in my opinion. Moving the pin and or bore size changes are outside of the SPIRIT of the rules however-- in my opinion. The intention of the piston rule was to make it accessible for the novice to call Summit or any place like that and order the same parts if they so desired. I didn't really want special "rubbed on/massaged" custom trick parts that the average onlooker wouldn't really understand or have access to. In the end I will never really know what a builder does or does not do--but thats where the honour system comes into play. Again--there's no purse so..... J.RobYes! Rarely listed though since 360’s are not known for an .080 capable bore size. But KB will have these. It’s a simple call to tell them. If it needs to be a place to call up and get them, Hughes engines has them listed. I would myself not call this a custom piston. Perhaps @RAMM might disagree, IDK?!?!
I also noticed shopping around that a standard bore 360 piston isn’t as prevalent as one might think. Though I’m sure there in or at the store/manufacturer’s shelf somewhere.
One of the cool things about most piston manufacturers, is they don’t consider a change a custom piston unless it’s after 1 or 2 changes. It depends on the piston manufacturer.
You can call them and say something like, on this here piston, I’d like deeper valve cuts for a mister lift cam I’m using. It has *** lift. And they’ll take a minute to cut the valves deeper for you.
Or thinner rings or a moved pin. But if you ask for more than what they say is their limit, 1, 2, or 3 changes, “Custom Piston” time! It’s a manufacturer call.
Gotcha. This is what I thought the case was.As long as the piston carries a SHELF STOCKING NUMBER. It isn't a custom in my opinion. Moving the pin and or bore size changes are outside of the SPIRIT of the rules however-- in my opinion. The intention of the piston rule was to make it accessible for the novice to call Summit or any place like that and order the same parts if they so desired. I didn't really want special "rubbed on/massaged" custom trick parts that the average onlooker wouldn't really understand or have access to. In the end I will never really know what a builder does or does not do--but thats where the honour system comes into play. Again--there's no purse so..... J.Rob
Not me, I don’t care. I’m also not using the biggest cam I have, the highest flow cylinder heads, biggest header or a tunnel ram for this fun build.I'm curious what people think the max output numbers will be and at what rpm.
Did the put an RPM limit in the rules….I'm curious what people think the max output numbers will be and at what rpm.
Building is a stretch. Ma mopar could take most of the credit. I’m not quite ready to say I’m in 100% but there is a solid chance I will submit an entry. I have a few “irons in the fire” and I’ll leave it there for right now. As soon as I know a timeline for the challenge I’ll be able to know more.@TT5.9mag, are you building anything?
I was in the middle of repairing W2 heads with replicaracer43’s guidance. I just reassembled them for later. After this build, I’ll get back to them.Building is a stretch. Ma mopar could take most of the credit. I’m not quite ready to say I’m in 100% but there is a solid chance I will submit an entry. I have a few “irons in the fire” and I’ll leave it there for right now. As soon as I know a timeline for the challenge I’ll be able to know more.
I need a run stand any recommendations?Mine will be a little different because it’s currently assembled and running. Albeit with turbos and a completely different camshaft and compression than I would use for the challenge. But that stuff can easily be changed. Easy because it’s on a run stand and not in the car.
I built my own garbage. I went down to the local steel supply house and bought box beam that slid into each other. The basic size was 2X2 inch. It to length and welded at home & away I went.I need a run stand any recommendations?
Pm meI need a run stand any recommendations?
