If you can mix Nitro with the meth, I dont see why not. Fully ported W9 with that fuel combo, 15-16 to 1 compression, the right cam, the right intake(can you run dual carbs?)
4.200" bore, 3.79" stroke, 6.500" rod in a 48* block. Fully ported W9's will flow some air, 360-370cfm. Power would be in the 5000-9000rpm range
I hope you have deep pockets, this would be about a $40-50K USD build Im guessing.
Got it. What type of block you use? A block would be 340? I need to score 8 seconds... maybe 7s..!! Naturally Aspirated..!!!
I would think 2-1050's and a good Hogan or Wilson manifold would be required to get there.
You communicate just fine :icon_smi:. This will be the baddest n/a SBM in So.America. I love it! :thumbrig:
Good luck! Mopar Or No Car!
im using a 73' 340 block that has been 1/3 filled, 4 bolt splayed billet mains, a crank gurdel (i spelled that wrong), and a whole lotta good strong parts!
If you can mix Nitro with the meth, I dont see why not. .
How much Nitro are you going to run???? Up to 20% is somewhat predictable, after that your in no mans land and better have a strong knowledge on that fuel. Nitro is some pretty bad stuff to deal with.
intereszting thread - not too much I can add, but my brother built a solid cam, 13.5 to 1 comp. 460 ford for a ralley 4x4 truck and with twin 750 holleys had the highest dyno pull of 850 horse.
twin 1050's would be a ton of flow, the old truck responded perfect between 4000 and 8500 rpm
I hope that you post video of this monster running.....
Wow.... I have never seen a Carb for something like this?
Most of the stuff I know of is Injected..... ????
But i'm liking the concept !!!!!!
