I think the Summit cam that has 216*/.454" cam will be nice. I dont Know the part number off hand. It is the old Crane Cam grind. I ran one in a 360 with stock high stall converter and was excellent.
Summit still has crane grinding those single pattern grinds, too.....
111.00 for cam and lifters..
Brand:
Summit Racing
Manufacturer's Part Number:SUM-K50052
Part Type:
Camshaft Kits
Product Line:
Summit Racing® Cam Kits
Summit Racing Part Number:SUM-K50052
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,500-5,200
Intake Duration at 050 inch Lift:216
Exhaust Duration at 050 inch Lift:216
Duration at 050 inch Lift:216 int./216 exh.
Advertised Intake Duration:272
Advertised Exhaust Duration:272
Advertised Duration:272 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.454 exh.
Lobe Separation (degrees):110
Computer-Controlled Compatible:No
Lifters Included:Yes
Lifter Style:Hydraulic flat tappet
Valve Springs Included:No
Retainers Included:No
Locks Included:No
Valve Stem Seals Included:No
Timing Chain and Gears Included:No
Assembly Lubricant Included:No
Pushrods Included:No
Rocker Arms Included:No
Gaskets Included:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Fair idle, good low midrange power. Largest stock engine cam, but works best with 9:1 and higher compression and gearing.
Quantity:Sold as a kit.
