If the clutch has a bi-metallic spring on the front of it, it should freewheel when cold.
I've ran across a clutch that does not have the spring that declutches when higher rpms are reached. The theory with this clutch is that you're going fast enough to push air through the radiator and that you're just wasting horsepower driving a fan.
