Nothing on ebay at the moment.You can also watch Ebay for Thermoquad Strip kits to suit your carb. Not cheap but worthwhile
I paid $500 for my kit complete. The come up now and then you just need to be patient.Nothing on ebay at the moment.
I found this site: tgmotorsports.net. They have two 10-203 kits, both opened and with only 2 pairs of rods in each. The 10-203 should have 6 pairs and they are asking $450 for a kit.
That's what I have heard and I was thinking that getting something close to what was used on a 440 and then change the primary jets if needed.I have been using TQs since the late 70s. They do not seem too fussy about exact metering steps.
The 9097S came on a -76 400 LB so the original jetting might be off. The 10-203 kit would be perfect. But paying $450 for a incomplete kit not knowing what you get ?From the Carter carburetor parts catalog:
Carter 9097
Primary Jet 120-4099 - orifice size .099
Rod 75-2086 - dimensions are .069 x .061 x .040
There are many sources that show what came in the Carter 10-203 strip kits.
Ok, thanks. Could you check and list what's remaining in the kit? Especially the rods.Here is one of my strip kits still for sale.
[SOLD] - Thermo-Quad Strip Kit Partial 72 up Solid Fuel 10-203
Thermo-Quad Strip Kit Partial 72 up Solid Fuel 10-203. Some parts may be slightly used, not by me. Three pairs of rods are missing and the 120-5149 secondary jets. $120 OBO + shipping.www.forabodiesonly.com
Yes, I probably do over think this (as I often do).[1] Mecki, you are over thinking this.
That's a reasonable explanation for that tube. It would probably do more harm leaving it open on a relatively stock 440 with A/T or?[2] The tube in post #34 has probably been added. Some TQs used that port for a hot idle compensator. Somebody may have used that carb with a huge cam that needed a lot of bypass air, & used that hole for bypass air.
[3] I have only ever found two sizes used for the sec high speed air bleeds. Early carbs used 0.039" along with big jets [ like 0.149"]; some later carbs used 0.029" air bleeds with smaller jets [ some had 0.098" sec jets, smaller than the pri jets. Go figure! ]
[4] I enlarge the sec air bleed to 039 on all TQs & use the bigger jets.
[5] Some later TQs had 0.101" pri jets, buuuuut they also had larger air bleeds. not sure why, presumably for emissions.
Ok, thanks for that information. Luckily it looks like the rod problem is going to be solved.[6] I would NOT be using AFB rods in TQs. first, you would want to check to see if the total travel of the rod is the same for the TQ & the AFB. Probably isn't. Also, the power step on AFB rods is usually longer than on the TQ rods, so a fundamental difference there.
I suppose that 440 was nothing but stock. I will look for that thread.[7] Since you have the carb apart, you may want to do the mods I listed in a thread in this section in Oct 2023. Those mods will make a veeeeeery noticeable performance improvement. On a 440 that I built for a 68 Charger, 5 speed man, TQ modified as above, it spins the wheels in 3rd gear when the secondaries open....
Just be aware that the AFB/AVS rods are thicker than the TQ rods so you’ll ether have to have the ends turned down to fit the TQ tree or remake the TQ rod holder.I saw somewhere rumblefish360 mentioning that an AFB rod can be cut and bent to fit a TQ.
Thanks for that info. I start to think that instead of trying to modify some existing rod easier would be to start with a straight 2,0mm (=.079) brazing rod. That diameter is already close to the first step. The holes in the holder (the one I have) are 2,2mm (=.087) so that would be a perfect fit when the rod is bent. The steps could be made in D-shape with a fine file with the uncut rod supported in a 2,0mm hole drilled in a piece of wood shaped so that it's partly exposed in the middle. Finally cut and bend. Some simple math in a excel table to compare the round and D-shape areas to know how much to file off the rod.Just be aware that the AFB/AVS rods are thicker than the TQ rods so you’ll ether have to have the ends turned down to fit the TQ tree or remake the TQ rod holder.
The cover casting clearly has a provision for something (hot idle compensator, two-way bowl vent) that has not been installed. The tube looks homemade, same sharp edge on both ends as when you cut with a hand tool. The base plate doesn't have the canister vent tube for two-way bowl vent installed, if it was the hole through the base plate would connect it directly to manifold vacuum.The tube clearly has not been added. It has its own bosses on the casting. It was cast with that tube as is.
In other words, it's just like the other tubes on it. None of them were works of art. Maybe it was added. It certainly doesn't look like it.The cover casting clearly has a provision for something (hot idle compensator, two-way bowl vent) that has not been installed. The tube looks homemade, same sharp edge on both ends as when you cut with a hand tool. The base plate doesn't have the canister vent tube for two-way bowl vent installed, if it was the hole through the base plate would connect it directly to manifold vacuum.
I'm not sure about that tube, I don't see the purpose of having it there. The hole drilled through the base plate makes no sense other than what Bewy suggested.
View attachment 1716317836View attachment 1716317837
You are right. It's hard to tell just by looking at the finish. I'm more concerned about that hole in the base. I'll just put a rubber cap on the tube and it's blocked.In other words, it's just like the other tubes on it. None of them were works of art. Maybe it was added. It certainly doesn't look like it.
I saw some other models with that same cover casting have the hot idle compensator fixed with two screws in that place.Spotted something on eBay that may be of some interest.
There are two Carter 9097 carbs listed for sale and one Carter 9097 listed under sold.
None of these have that opening in the air horn.
I've never seen a HIC on a thermoquad. Mostly on AFBs and AVS.I saw some other models with that same cover casting have the hot idle compensator fixed with two screws in that place.
I had a suspicion they may have been, I've just never seen one.Hot idle compensators were used on many TQs. As correctly Mecki says in post #45, they were held with two screws.
