Thermoquad fuel bowl cups?
nothingbutdarts
Bailey, Co.
What do you guys use to glue the cups back on the bottom of the T/Q fuel bowls tah come unglued and fall off?
JB Weld?
That'll work, I used it for a fuel bowl. No issues.
No. don't do it. JB Weld is NOT impervious to gasoline. You need to use a two pary epoxy that is. JB weld is not. It will work short term, but it will eventually turn loose.
I've heard that but never knew what type of epoxy to get.
No. don't do it. JB Weld is NOT impervious to gasoline. You need to use a two pary epoxy that is. JB weld is not. It will work short term,but it will eventually turn loose.
JB Weld I use is a two part epoxy. However what would you suggest using?????
Do you mean "turn loose" like the stuff Ma MOPAR uses!!!!!!
All JB Weld is a two part that I know of. It's just not gasoline resistant.....even though it says that it IS......it is NOT. I forget the name.....but 3M makes some good stuff. It comes in one of them dual syringe lookin things. Yes, when I say let loose, I mean they will fall the hell off. lol
That looks like good stuff. and you aint gotta mess with mixin it up. I might need to get me some of that. Thanks.
