Thermoquad Identification Help
Moparone
New Boston Michigan
I have a thermoquad off of a 73 Duster 340 4 speed. The car it is off of is very complete and original and I think the carb is original equipment. However, I am unable to identify it with the numbers I have been able to find and was wondering if someone has any input on this. According to reference guides the carb # should be: 6318s. However on the lower left corner of my carb I see a: 0022s. There is also a 319 3 shown. Neither of these numbers are on any of the reference sheets I have found, and am not sure what they mean. Any help would be greatly appreciated.
Probably 9022s Not in my book but appears to be early 70's Chrysler linkage, maybe lean burn. I don't see the ported vacuum tap. Maybe truck?
Thanks for the input. I am going to go a non stock route, so I won't need the correct carb. I will probably list this one for sale.
It's 9022S, like streetkit said. It's a good core. Use it. The "California Emissions" had little if anything to do with the carburetor on a truck in 1974. It is for all intended purposes a non smog carb. It's a goodun.
Rusty knows his TQs.
