Leaking fuel wells & leaking o rings are two different problems & have different symptoms.
Leaking FW:
- IF the lower gasket [ base to bowl ] is intact, idle is unaffected but you get a rich off idle.
- if this gasket is broken where it seals the throttle bore, then fuel will seep into the bores & cause a rich idle.
Leaking o rings:
- will cause rich idle & generally rough running, depending on how bad the leak is.
Leaking FW:
Leaking o rings:
