demon sizzler
- Joined
- May 26, 2004
- Messages
- 182
- Reaction score
- 6
I see you also have a notch in the intake itself....what is that for? also, is there a way to increase the cfm of the tq wihtout removing the choke horn?
The notch is there for clearance for the three bbl carbs; Holley and the ultra rare Carter AFB.
You can increase the total cfm's by 60 with the removal of the choke plate. This can easily give you another 20-25 hp on the 850 cfm and 15-20 hp on an 800 cfm. If you do this, you will have to increase the jet size on the primary side, David.
