Thinking about the future project
GeorgeGerhard
Shelton, Ct
Hello
I am thinking about one of my future projects. Rewiring the car
I noticed that 440 source sells a Denso 60 amp one wire alternator with the correct mounting hardware.
What do you guys think about this?
Also will 60 amps be enough if I decide to go to electric fan(s)
http://www.440source.com/altparts.htm
thank you
George
that looks like a good way to go,a lighter alternator,less wiring and a cleaner looking engine compartment.
Electric fans are usually the biggest electrical draw in the system and are likely fused around 30A so with one fan plus everything else in the car you should be fine but you probably could'nt run two of them with a 60A alternator.
