Thompson’s Powerblast Plate
I usually come through Wyoming cut through Laramie and down to Fort Collins and down to Denver and back up that way. I've never cut east across I-70. Also cutting across that way I never seen the altimeter go much above 7000.
South at Laramie is a neat drive.
I've got a 750 street hp on 440 Yorker intake roller cam. Harland sharps rockers. Stall is about 3700 ish. Mine bogs a bit then runs great. Figured I'd try there. Maybe I'll record a real before after videoes. I'm very curious to see how these go. I had two order two for my application
I lived in Cheyenne for a few years and was high most of the time????? Think it was around 6000ft.
Did you ever try the plates to see if they helped your bog.
