ArizonaKid
I have a 1976 super six motor, its probably got at least 100,000 miles on it, and since I decided to put a 318 into my dart, I wanted to set aside some money for a rebuild, and get a parts list ready. The motor is all stock, except for the timing chain I replaced, stock springs, valves, pistons, cam and lifters.
So what I figured would be good was; new pistons for a higher compression, I think these motors were around 8.4 to 1. A new cam, and maybe lifters, I want to know if its better to use new lifters, or keep the original hollow mechanical lifters. New valves and a head job. And finally, new springs.
I wanted to know what you guys used and liked, the compression I would shoot for would be in the 9.5 to 1 range, so nothing too radical or racy cam wise. The motor would be for nothing more than a daily driver, but eventually I might put a turbo setup on it, if I get a good deal on one.
