Thoughts on the 452 heads looking for opinions on building a set of 452 heads for a 498 stroker please let me know what you’re thinking I am thinking a set of big valves and some porting work
Yeowza!!I think the first porting I did was 59 years ago
I have a question your inbox is fullI have a set of home ported 915s with 2.14-1.81 valves. Don't know what they flow, but lost e.t. when I bolted on stock pro comps. And their 40 lbs. lighter. It was alot of work. Once I ported the pro comps it was a different story.
Sorry trying to clean it. should be good now.@aaronk785
Sir trying to PMU your inbox is full
They are the rpm copies. My freinds talked me into it. Said I would pick up. I was very dissapointed. I bought them bare and added quality valves, springs and retainers and run of the mill 3 angle valve job.
