MidnightSwinger
My 1965 Dart came with no motor or transmission. It was originally 3 speed manual on the column. I’m trying to decide if I should keep it that way.
I have very limited experience with column shifted manuals, so I’m looking for some information and advice on what to do.
After some research I see that the factory column 3 speeds were the 745/903 and later the a230.
Will the a230 column shift transmission work in the 65? It seems like it would be the transmission to have since it’s fully synchronized.
If not which is better between the 903/745 for my application? Were they all the same length, or are they chassis specific like the A833?
It’s going behind a mild built 225, estimated at 200 Hp and 250 ft lbs.
What would you do?
What would you do?
