throttle bracket/cable interchange?
Rapid Robert
Lincoln Nebraska
63 dart was a /6. has the 3 mounting holes in the firewall roughly in a triangle. will a 64-66 A body V8 throttle bracket/cable bolt into the same holes? thank you for your time. RR
How about a photo of your firewall and some measurements between the bolt holes.
I cannot get my camera to upload on this computer. the three bolts form a triangle pointing down. the holes in the 2 o'clock and 10 o'clock positions horizontle are ~2&5/16" across. the bottom hole at the 6 o'clock position is ~ 1&3/4" diagonal from either of the top horizontle holes.
No, that's not the pattern that the '64-6 cars have. Your firewall will be different too, and needs to be modified to accept a V8.
Thank you! that tells me that I dont even need to consider the $80 V8 one that is available. Well I just about have the sheath measured/cut to the right length & I'll know soon if the superglue will hold it in place.
