Throttle cable suggestions
Paul Davidson
Texas
I have a sniper sitting on a 1 in.spacer and a edelbrock air gap manifold in a 67 barracuda 4 speed car
There are three different A-body factory throttle cable lengths, V8 4bbl being the shortest , V8 2bbl in the middle and slant 6 being the longest. I used a V8 2bbl on this high intake. slant 6 is much longer. I like using factory throttle cables I find them to be more durable.
a factory /6 cable with the correct bracket (you'll likely have to fab) should get you there.
unless the throttle arm for the sniper is much further forward, it shouldn't be a problem.
