Throttle cable
olddman
Cypress, Texas
I have a 1965 Dodge Dart GT with a commando 273. Need to install a throttle cable on my 904 transmission. How do I do this and how do I adjust it.
Thanks,
Olddman
Hey olddman: The 65 V8 A's had a three piece rod and bellcrank system to control the transmission lever. If you're missing all of that and want to install a cable setup, then either Lokar or Buchillion (sp) sell kits to accomplish this.
You adjust the linkage / cable so that when your carb is at WOT the transmission lever is all the way to the rear, thus giving maximum fluid pressure when it's most required.
